[gdal-dev] Re: Copy only georeference between two images
christian.mueller at nvoe.at
Mon Sep 13 11:35:08 EDT 2010
I see your image is LZW compressed, AFAIK this is the same for png images.
Try the following
1) use gdal_translate to create a png file and a corresponding world
file from your shifted image.
2) Open the world file with an editor and adjust the values
3) use gdal_translate to create a geotiff from the png file.
The interesting options are
-a_srs EPSG:32631
-co "COMPRESSION=LZW"
-of TIFF
4) Use gdalinfo and check the result
Perhaps there is a shorter way, but this is the way I would try it.
Cheers
Christian
Quoting canduc17 <candini at meeo.it>:
> It is the same, but the georef information is a little bit shifted.
> So I have to copy the first georef into the second image.
> http://osgeo-org.1803224.n2.nabble.com/Copy-only-georeference-between-two-images-tp5526582p5526728.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
