[gdal-dev] The 2.5D geometry proposal
Oyvind Idland oyvind.idland at gmail.com
Thu Sep 16 08:33:12 EDT 2010
Hi Ralf,
full 3D/volumetric objects was not what I was refering to. I mean
"2.5D", simple features
with Z (and M) ordinates.
If I understand correct, this is what Adam is refering to in his proposal.
SQL/MM do specify Z and M geometries (plus circular geometries).
Oyvind
On Thu, Sep 16, 2010 at 2:23 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de> wrote:
> Hi Oyvind,
> there no 3D in ISO SQL/MM part 3. If you want real 3D, you have to define
> volumetric objekts. PostGIS support SQL/MM part 3.
> Gr
> Ralf
> Am Donnerstag 16 September 2010 14:03:09 schrieb Oyvind Idland:
>> Hello,
>> been taking a look at "Adam's 2.5D simple features proposal" at the OGR
>>  website.
>> Question: Why not adopt the existing ISO SQL/MM part 3 standard ?
>> The SQL/MM standard is an extension to the existing WKB/WKT by OGC.
>> The extensions includes Z and M geometries, and even arcs
>> (CircularString/CompoundCurve etc).
>> regards,
>> Oyvind Idland
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
