[gdal-dev] GDALDataset blocks in different thread
Even Rouault even.rouault at mines-paris.org
Thu Sep 16 13:27:07 EDT 2010
James,
what you see is a bit surprising...
Do you build GDAL by yourself or use a packaged version ? If you build it
yourself, you explicitely need to specify --with-threads at ./configure time
(unless you use the latest trunk version where it is now the default). In
port/cpl_multiproc.h, you can see #define CPL_MULTIPROC_PTHREAD 1 if everything
works. If you have only the .so, you can for example try using the
CPLCreateThread() method. If it returns -1, then you have the stub
implementation.
Could you try compiling and running the following code that is an attempt to
have a minimum scenario that reproduces what you descrbe ?
#include <gdal.h>
#include <gdal_alg.h>
#include "cpl_multiproc.h"
void my_thread(void* pData)
    GDALDatasetH hDS;
    int checksum;
    hDS = (GDALDatasetH)pData;
    printf("in thread\n");
    checksum = GDALChecksumImage(GDALGetRasterBand(hDS, 1), 0, 0, 20, 20);
    printf("checksum = %d\n", checksum);
int main(int argc, char* argv[])
    GDALDatasetH hDS;
    GDALAllRegister();
    hDS = GDALOpen("byte.tif", GA_ReadOnly);
    CPLCreateThread(my_thread, hDS);
    CPLSleep(2);
    printf("finished\n");
    return 0;
It works fine for me. The byte.tif is available at
http://trac.osgeo.org/gdal/export/20628/trunk/autotest/gcore/data/byte.tif
Otherwise, which OS are you using ?  which GDAL version ? Which GDAL driver is
used by your dataset ? etc etc ? If you run it under gdb, what is the stack
trace when it is blocked ?
Even
Le jeudi 16 septembre 2010 10:23:27, James Meyer a écrit :
> Hi
> I am opening a GDALDataset in my main thread which I then pass to a
> second thread for processing. Only the second thread accesses the dataset.
> As soon as the thread makes a call to GDALRasterBand::RasterIO() the
> thread blocks indefinitely.
> Could you please explain to me why this is happening?
> Also, how do I check whether my build of GDAL was built with the
> --with-threads option enabled?
> Thanks
> James
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
