[gdal-dev] gdal_fillnodata.py doesn't work
ahmet temiz
ahmettemiz88 at gmail.com
Wed Sep 22 07:23:53 EDT 2010
thank you for your interest
here it is:
orkun at orkun-desktop:~/data/pro1001/yuk$ gdalinfo work1.tif
Driver: GTiff/GeoTIFF
Files: work1.tif
Size is 4716, 5481
Coordinate System is `'
Origin = (436921.710000000020955,4648461.900000000372529)
Pixel Size = (20.000000000000000,-20.000000000000000)
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 436921.710, 4648461.900)
Lower Left ( 436921.710, 4538841.900)
Upper Right ( 531241.710, 4648461.900)
Lower Right ( 531241.710, 4538841.900)
Center ( 484081.710, 4593651.900)
Band 1 Block=4716x1 Type=Float64, ColorInterp=Gray
NoData Value=0
regards
2010/9/22 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> ahmet,
> This error is reported by the grass library.
> Is "work1.tif" in TIFF format? Can you post the output of gdalinfo on
> work1.tif for more info?
> On Wed, Sep 22, 2010 at 1:50 PM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
>> hello
>> can you tell me what this problem is ?
>> orkun at orkun-desktop:~/data/pro1001/yuk$ python gdal_fillnodata.py -md
>> 100 work1.tif dem1.tif
>> ERROR 1: libgrass: MAPSET is not set
>> Aborted
>> regards
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
