[gdal-dev] gdal_fillnodata.py doesn't work
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Sep 22 12:06:29 EDT 2010
ahmet,
I can't understand why the error occurs. Can you provide a sample data that
gives this error?
On Wed, Sep 22, 2010 at 4:53 PM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
> thank you for your interest
> here it is:
> orkun at orkun-desktop:~/data/pro1001/yuk$ gdalinfo work1.tif
> Driver: GTiff/GeoTIFF
> Files: work1.tif
> Size is 4716, 5481
> Coordinate System is `'
> Origin = (436921.710000000020955,4648461.900000000372529)
> Pixel Size = (20.000000000000000,-20.000000000000000)
> Image Structure Metadata:
>  INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  436921.710, 4648461.900)
> Lower Left  (  436921.710, 4538841.900)
> Upper Right (  531241.710, 4648461.900)
> Lower Right (  531241.710, 4538841.900)
> Center      (  484081.710, 4593651.900)
> Band 1 Block=4716x1 Type=Float64, ColorInterp=Gray
>  NoData Value=0
> regards
> 2010/9/22 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> > ahmet,
> > This error is reported by the grass library.
> > Is "work1.tif" in TIFF format? Can you post the output of gdalinfo on
> > work1.tif for more info?
> > On Wed, Sep 22, 2010 at 1:50 PM, ahmet temiz <ahmettemiz88 at gmail.com>
> wrote:
> >> hello
> >> can you tell me what this problem is ?
> >> orkun at orkun-desktop:~/data/pro1001/yuk$ python gdal_fillnodata.py -md
> >> 100 work1.tif dem1.tif
> >> ERROR 1: libgrass: MAPSET is not set
> >> Aborted
> >> regards
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > /tʃaɪθənjə/ /kʊmɑr/
> > +91-9494447584
> > 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100922/2bcded79/attachment.html
