Re: [gdal-dev] svn build on mac osx 10.6.4 (errors in GDALmake.opt)
Ivan Lucena
ivan.lucena at pmldnet.com
Wed Sep 22 08:08:32 EDT 2010
Eccellente!
But strange. I have a system just like yours and I don't need to do that. :!
Regards,
Ivan
> -------Original Message-------
> From: Massimo Di Stefano <massimodisasha at gmail.com>
> To: Massimo Di Stefano <massimodisasha at yahoo.it>
> Cc: gdal-dev <gdal-dev at lists.osgeo.org>
> Subject: Re: [gdal-dev] svn build on mac osx 10.6.4 (errors in GDALmake.opt)
> Sent: Sep 22 '10 03:58
> Fixed using the path to python-config during the ./configure :
> --with-python=/usr/bin/python2.6-config
> Il giorno 22/set/2010, alle ore 09.07, Massimo Di Stefano ha scritto:
> Hi ,
> any clue about this message :
> "GDALmake.opt:50: *** missing separator. Stop. "
> i have it tring to run "make "
> on mac osx 10.6.4
> 1 2 3 4 5 6 7 8 9 10 11 12
> PYTHON_INCLUDES = @PYTHON_INCLUDES@ PYTHON_LIBS = @PYTHON_LIBS@
> PYTHON_CFLAGS = @PYTHON_CFLAGS@ @NUMPY_FLAG@ PYTHON = python PYTHON_DEV =
> @PYTHON_DEV@ PY_LD_SHARED = @PY_LD_SHARED@ PY_SO_EXT = @PY_SO_EXT@
> PY_HAVE_SETUPTOOLS=Leopard libedit detected. 1 # Next Generation SWIG
> bindings BINDINGS = python
> (line:9 = line:50 in GDALmake )
> i used a "standard "
> ./configure,
> on gdal svn-trunk_______________________________________________
> gdal-dev mailing list
> [LINK: mailto:gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
