[gdal-dev] Backward incompatible changes in the OGR style string format (r19724)
Tamas Szekeres szekerest at gmail.com
Thu Sep 23 14:06:51 EDT 2010
2010/9/23 Daniel Morissette <dmorissette at mapgears.com>
> Updates have to be committed upstream, ideally by submitting a ticket at
> http://bugzilla.maptools.org/ ... eventually I should open the MITAB CVS
> repository to more GDAL committers to facilitate this process.
> I have to admit that as new GDAL committers have started making changes
> to ogr/ogrsf_fmrts/mitab without making sure the fix is propagated
> upstream we've kind of lost control and are in front of a bit of a mess
> at the moment.
Daniel,
Count me as a "new" committer as I've also done some changes in this part,
however bug has also been added with these changes at
http://trac.osgeo.org/gdal/ticket/3687 ;-)  We may indeed forget to
duplicate this into the other BugTracker which would require a more
advertised policy to follow. Or we could leave the things as it is, and
periodically update all the changes in gdal back to the main stream.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100923/7681c2bd/attachment-0001.html
