[gdal-dev] Backward incompatible changes in the OGR style string
format (r19724)
Daniel Morissette
dmorissette at mapgears.com
Thu Sep 23 14:50:02 EDT 2010
Tamas Szekeres wrote:
> Count me as a "new" committer as I've also done some changes in this
> part, however bug has also been added with these changes at
> http://trac.osgeo.org/gdal/ticket/3687 ;-) We may indeed forget to
> duplicate this into the other BugTracker which would require a more
> advertised policy to follow. Or we could leave the things as it is, and
> periodically update all the changes in gdal back to the main stream.
And I remember that you did contact me to ask about this but I failed to
follow up with you... the mess I am referring to is not only due to GDAL
devs committing fixes (which is great in most cases), it's also due to
me not having/taking the time to followup on all the changes so I'm in
large part to blame for lack of action.
Pusing that action item higher on my TODO list again...
Daniel
Daniel Morissette
http://www.mapgears.com/
