[gdal-dev] Re: NITF driver reads GEOLOB, but does not write it.
Even Rouault
even.rouault at mines-paris.org
Thu Sep 23 16:38:13 EDT 2010
No, you must not write CETAG = 'GEOLOB', ... as the value of the TRE. You must
really format the TRE byte by byte, without any separator or field name,
according to its documentation.
gdal_translate -of NITF foo.tif foo.ntf -co
"TRE=GEOLOB=073932800080076800-096.9774560321+045.1446198929"
Le jeudi 23 septembre 2010 22:32:44, turtlewax a écrit :
> Even, thanks for responding. The ultimate goal is to serve up NITFs via
> MapServer. So if we need to specify a TRE option, we would need to define
> it in the mapfile.
> Still, this is a good lead. Do you have any guidance on exercising this
> from the command-line?
> gdal_translate -of NITF -co TRE=GEOLOB="CETAG = 'GEOLOB'\n CEL =
> '00048'\n ARV = '073932800'\n
> BRV = '080076800'\n LSO = '-096.9774560321'\n PSO =
> '+045.1446198929'\n IS_OVERFLOW = 0" foo.tif foo.ntf
> Input file size is 1543, 1670
> ERROR 1: Cannot read GEOLOB TRE. Wrong size.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
