[gdal-dev] ogr problems with MapInfo
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 09:40:15 EDT 2010
done... didn't work...
Copied on the same SMB folder with undercase names... both ogrinfo and
tab2tab failed.
Copied the same files to a local folder and both ogrinfo and tab2tab
succeeded...
same errors....
On Thu, Sep 30, 2010 at 1:44 PM, Daniel Morissette <dmorissette at mapgears.com
> wrote:
> Sebastian E. Ovide wrote:
> > can verbosity be increased further ?
> I don't think so... the only way to know more about what is happening
> would be to run this in gdb.
> > and with TAB2TAB the only messages that I get are:
> > gis at mapserver:/tmp$ /home/gis/src/mitab-1.7.0/mitab/tab2tab
> > /home/gis/data/tmp/CA_AbandonedMine.TAB test.TAB
> > ERROR 3: stat() failed for /home/gis/data/tmp/CA_AbandonedMine.id
> > ERROR 3: Open() failed for /home/gis/data/tmp/CA_AbandonedMine.map
> > ERROR 3: /home/gis/data/tmp/CA_AbandonedMine.TAB could not be opened as
> > a MapInfo dataset.
> > Failed to open /home/gis/data/tmp/CA_AbandonedMine.TAB
> This looks like an uppercase vs lowercase file extension problem. There
> is some logic in MITAB to try to guess and then adjust filename
> extensions (e.g. .MAP vs .map) on non-Windows systems that uses stat()
> and for some reason it seems to fail with the SMB share.
> Can you please try renaming all files for a given table to lowercase
> extensions (.tab, .map, .dat, .ind, .id) and then see if that changes
> anything with the tab2tab program on the SMB share?
> If that solves the issue then we'll need to reproduce this here and run
> this in gdb to figure the exact source of the problem and fix it.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100930/42077cad/attachment.html
