[gdal-dev] ogr2ogr: problems converting from shapefile to kml
Vishal Mehta
vishal.mehta at sei-us.org
Wed Apr 6 19:34:39 EDT 2011
Thanks Even,
I was trying to overlay the kml on top of my crowdmap which uses OpenStreetMaps (which is in EPSG 900913 or 3857) as baselayer. When my kml did not appear, I thought I had to reproject it to the projection of the baselayer..
Looks like the problem lies elsewhere - maybe the ogr2ogr-output kml is missing a scale or size tag for the points...or something like that
best,
Vishal
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Wednesday, April 06, 2011 4:02 PM
To: gdal-dev at lists.osgeo.org
Cc: Vishal Mehta
Subject: Re: [gdal-dev] ogr2ogr: problems converting from shapefile to kml
Le jeudi 07 avril 2011 00:39:59, Vishal Mehta a écrit :
> Hi all,
> I'm having some trouble with a simple conversion from shapefile to kml.
> Description
> 1. I need to have a points file in kml that is is EPSG 3857 (the mercator
> that Google uses)
I'm afraid that you are loosing your time. KML coordinates must be expressed
in EPSG:4326 per the spec.
See http://code.google.com/intl/fr/apis/kml/documentation/kmlreference.html
and specifically :
"""<Location>
Specifies the exact coordinates of the Model's origin in latitude,
longitude, and altitude. Latitude and longitude measurements are standard lat-
lon projection with WGS84 datum. """
This is also reminded in the OGR KML doc : see
http://gdal.org/ogr/drv_kml.html
