[gdal-dev] Can't read transformation coefficients from tiff
Goo Creations goocreations at gmail.com
Thu Apr 7 04:26:44 EDT 2011
Hi all
I tried to read the transformation coefficients by using
GDALDataset::GetGeoTransform. This function however returned CE_Failure, so
i assume that the values are not stored in the metadat.
When I view the image, the image is rotated. There is no world file or
anything that could cause the rotation.
So my question: If these values are not stored in the metadata, how does
GDAL handle the rotation, pixel size, etc?
Chris
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110407/a272892d/attachment.html
