[gdal-dev] Windows link issue with Poppler/PDF
Joaquim Luis jluis at ualg.pt
Sun Apr 10 13:52:20 EDT 2011
Jeff,
I get the same thing (VS2010 ). I could only link the 0.14 built for 32
bits. For 64 there were some other problems that I don't remember anymore.
Joaquim
> Hello,
> On windows using Visual Studio 2008 I have compiled poppler.lib (from
> poppler-0.16.4, using cmake), excellent, and if I cd to /frmts/pdf and
> 'nmake /f makefile.vc' there are no problems; however during GDAL's
> link I get the following error:
> poppler.lib(GlobalParams.obj) : error LNK2005: _DllMain at 12 already
> defined in gdaldllmain.
> obj
>    Creating library gdal_i.lib and object gdal_i.exp
> gdal19dev.dll : fatal error LNK1169: one or more multiply defined
> symbols found
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 9.0\VC\BIN\link.EXE"
> ' : return code '0x491'
> Stop.
> (I have tried both GDAL-1.8.0 and trunk, same error)
> Anyone see what I am doing wrong, or give me some hints as to how to
> solve this "DLLMain already defined" problem?  Thanks.
> -jeff
