[gdal-dev] OGR2OGR PGeo reprojection with -sql
Smith, Michael D ERDC-CRREL-NH michael.smith at usace.army.mil
Mon Apr 11 14:32:53 EDT 2011
Thanks Even, that worked perfectly.
Mike
On 4/11/11  1:29 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le lundi 11 avril 2011 18:47:16, Chaitanya kumar CH a écrit :
>> Mike,
>> Can you provide the version number and perhaps a sample dataset that shows
>> this problem?
> No, need for it. This is the "expected" behaviour by looking at the code of
> the PGEO driver. It will be able to fetch the SRS only when working directly
> with layers, not with SQL requests. You could try specifying the -dialect
> OGRSQL option to ogr2ogr, in which case the SQL will be evaluated by OGR SQL
> engine and not by the ODBC engine. The OGRSQL engine should be able to
> retrieve the SRS from the layer.
>> On Mon, Apr 11, 2011 at 9:51 PM, Smith, Michael D ERDC-CRREL-NH <
>> michael.smith at usace.army.mil> wrote:
>>>  All,
>>> Using GDAL  trunk, I can read and reproject a personal geodatabase using
>>> the internal projection as the source projection. However, when I use
>>> ­sql (as I need to add a new field to the output), the source projection
>>> can no longer be read.
>>> C:\temp>ogr2ogr -t_srs EPSG:4326 -f "ESRI Shapefile" temp1.shp
>>> CL_01_LDS_20101201_A.mdb CL_01_LDS_20101201_A_Contour_Smoothed
>>> Warning 6: Normalized/laundered field name: 'Shape_Length' to
>>> 'Shape_Leng'
>>> CL_01_LDS_20101201_A.mdb  -sql "select * from
>>> CL_01_LDS_20101201_A_Contour_Smoothed"
>>> Can't transform coordinates, source layer has no coordinate system.  Use
>>> -s_srs to set one.
>>> Mike
>>> Michael Smith
>>> Remote Sensing/GIS Center
>>> US Army Corps of Engineers
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
