Re: [gdal-dev] Re: OGR/Spatialite patches
Ivan Lucena
ivan.lucena at pmldnet.com
Tue Apr 12 13:41:13 EDT 2011
Hi there.
Since Berkeley DB is SQLite API compatible, does anybody has experience with using Berkeley DB + Spatialite ? Would that be possible to work?
Thanks,
Ivan
> -------Original Message-------
> From: Even Rouault <even.rouault at mines-paris.org>
> To: Alessandro Furieri <a.furieri at lqt.it>, Frank Warmerdam <warmerdam at pobox.com>
> Cc: Andrea Peri <andrea.peri at regione.toscana.it>, gdal-dev at lists.osgeo.org, Paolo Cavallini <cavallini at faunalia.it>, Sandro Santilli <strk at keybit.net>, Maurizio Napolitano <napo at fbk.eu>, Alex Mandel <tech_dev at wildintellect.com>
> Subject: [gdal-dev] Re: OGR/Spatialite patches
> Sent: Mar 30 '11 15:07
> Hi Alessandro,
> (CC'ing gdal-dev)
> Impressive work !
> My remarks and questions:
> 1) Could you confirm that all this work might be included under the usual GDAL
> X/MIT licence ? Due to the significant code addition for the 3D geometry
> support, you might want to add your copyright in the header of
> ogrsqlitelayer.cpp.
> 2) It would be really convenient to have different patches for the different
> issues that could be applied sequentially. Applying all this stuff in a single
> gulp will make bisection and analysis of the changes quite painfull. I've
> skimmed quickly through the whole diff and your README and I can see several
> patches, preferably in the following order (if possible) :
> 1) 3D geometry support
> 2) use the spatialite SQL functions and drop the manual workarounds to
> avoid using spatialite functions
> 3) general cleanup to remove the use of ancient sqlite API (that seem not
> to be directly related to spatialite support)
> I'd be in favor of dropping the stuff related to #ifdef SPATIALITE_AMALGAMATION
> for now. Or it might be traced under a different ticket
> 3) From your patch I can see that my efforts to produce a spatialite database
> without linking to spatialite were vain. I'm not that surprised however.... So
> the question is : is there really an interest in allowing the user to create a
> spatialite database without linking to spatialite if that database cannot be
> directly used by other spatialite-enabled software ant that the user must
> "repair" it afterwards with the procedure at the end of your README.txt. This
> really sounds to be compatible with only super power users... We might also
> want to be sure that no write/update/delete operations can happen to a
> spatialite database if it is opened with a driver not linked against
> libspatialite to avoid corrupting it.
> However I think it is still desirable to be able to read a spatialite database
> without requiring linking to spatialite.
> 4) We must be aware that using the ALTER TABLE ... ADD COLUMN ... stuff will
> produce databases (even regular SQLite ones) that will not be compatible with
> the latest FWTools for Windows that uses an ancient sqlite versions. Might not
> be a big deal however because I somehow remember that dropping a new version
> of sqlite3.dll in the bin directory make it work again.
> 5) Would you be willing to update/extend the autotest/ogr/ogr_sqlite.py test
> to ensure that it still passes and add some tests for all the new stuff,
> particularly the 3D geometry support.
> 6) From your README.TXT, can I assume that your changes have been tested
> against regular libsqlite3 (without linking to spatialite) with a spatialite
> database (and also a regular sqlite database not using spatialite geometries),
> and against libspatialite 2.3.1 and libspatialite 2.4.0 for spatialite
> databases ?
> 7) A minor code note : it could be interesting to replace the magic values for
> the geometry types by appropriate #define with symbolic names.
> 8) I've seen you have removed the tests to detect int overflows, for example
> "if( nPointCount < 0 || nPointCount > INT_MAX / (2 * 8))" has become "if(
> nPointCount < 0)". Could you justify it ? I still think that they are
> necessary to avoid issues in lines below if the nPointCount value is huge
> enough.
> 9) About your [3c] patch. Yes indeed this is a painfull issue with shapefiles
> (the format I mean, not the driver) where we cannot know in advance if it only
> contains LINESTRING or MULTILINESTRING. Currently the shapefile driver chooses
> to report the layer as having LINESTRING geometry type. Maybe Frank can
> comment about this. I imagine this was decided because some application
> software wouldn't know to deal with multi-geometry. But I can confirm that
> inserting such shapefiles with mixed linestring/multilinestring geometries into
> Postgis requires a -nlt flag to the ogr2ogr command line. To get back to your
> patch, I'm wondering what will happen if we try to insert a feature with a
> LINESTRING geometry into a layer created with the LINESTRING geometry type,
> that has been "promoted" to MULTILINESTRING by the driver ?
> Best regards,
> Even
> Le mercredi 30 mars 2011 12:37:05, Alessandro Furieri a écrit :
> > Hi All,
> > I know for sure that all you are strongly
> > interested in both SpatiaLite and GDAL/OGR:
> > so I'm glad to submit to your attention a
> > patch-set intended to enhance the OGR/spatialite
> > driver.
> > - correcting several issues found into the current
> > implementation
> > - supporting the most recent features introduced
> > by v.2.4.0 [3D Geometries and so on]
> > You'll find everything within the attached zipfile:
> > - source code
> > - svn diff
> > - detailed explanations on README.txt
> > Please note: the current patch-set (although quite
> > thoroughly tested and debugged by myself) simply
> > represents a preliminary interim version.
> > I suppose some further (small) optimization would
> > be required before actually committing into the
> > SVN trunk.
> > Any suggestion, useful hint, criticism and testing
> > coming from you surely will be warmly welcome and
> > highly appreciated.
> > bye
> > Sando
> gdal-dev mailing list
