[gdal-dev] Reading of MSG Native Data
Simon R. Proud srp at geo.ku.dk
Tue Apr 12 13:54:00 EDT 2011
I've been testing GDAL with Native (.nat) format data from the MSG satellite, and have a slight problem.
gdal_translate fails to process the high resolution channel (Band 12, image size is variable but for my data 5568x4176).
The .nat files I'm working with only contain the HRV data, not the low res channels - but when I run gdalinfo the data I see listed looks like it is for the low res channels (image size of 3712x3712 and pixel size of 3km).
It may also be reading the wrong satellite position (0 degrees instead of 9.5E) although this may be a problem with the actual .nat file.
gdalinfo also displays an error (ERROR 1: tolerance condition error) for the corner coordinates of the image..
Is this a known issue? It would be great if there is a work-around for it.
All the best,
Simon.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110412/0017579b/attachment-0001.html
