[gdal-dev] GDAL Native Libraries 1.4.5b for Linux64 not available
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Apr 13 04:20:37 EDT 2011
Andreas,
The file exists. However, the GDAL 1.4 branch is no longer supported. The
latest stable version is 1.8 although 1.7 is also supported. Why don't you
use the 1.7 version.
http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/
On Wed, Apr 13, 2011 at 1:16 PM, Andreas Oxenstierna <ao at t-kartor.se> wrote:
>  Need to include GDAL support for GeoServer 2.1 on Linux 64-bit. However,
> it seems that the link to the native libraries on
> http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz
> is broken. Can I get the gdal1.4.5b-linux64-base.tar.gz from somewhere else
> or do I need to build it from the source files?
> Andreas Oxenstierna
> T-Kartan Produkt AB
> mobile: +46 733 206831
> mailto: ao at t-kartor.sehttp://www.t-kartor.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/9b6889a6/attachment.html
