[gdal-dev] GDAL Native Libraries 1.4.5b for Linux64 not available
Andreas Oxenstierna
ao at t-kartor.se
Wed Apr 13 04:29:17 EDT 2011
If I am interpreting the information correctly on
http://docs.geoserver.org/latest/en/user/data/gdal.html
GeoServer is using Image I/O-Ext 1.0.8 which is using GDAL 1.4.5, that
is my reason.
How can I get access to the file gdal1.4.5b-linux64-base.tar.gz
<http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz>
? I cannot download it from the link below with any tested browser,
instead getting a message "The page you were looking for doesn't exist".
Andreas
> Andreas,
> The file exists. However, the GDAL 1.4 branch is no longer supported.
> The latest stable version is 1.8 although 1.7 is also supported. Why
> don't you use the 1.7 version.
> On Wed, Apr 13, 2011 at 1:16 PM, Andreas Oxenstierna <ao at t-kartor.se
> <mailto:ao at t-kartor.se>> wrote:
> Need to include GDAL support for GeoServer 2.1 on Linux 64-bit.
> However, it seems that the link to the native libraries
> onhttp://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz
> is broken. Can I get the gdal1.4.5b-linux64-base.tar.gz from
> somewhere else or do I need to build it from the source files?
> Andreas Oxenstierna
> T-Kartan Produkt AB
> mobile: +46 733 206831
> mailto:ao at t-kartor.se <mailto:ao at t-kartor.se>
> http://www.t-kartor.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
Andreas Oxenstierna
T-Kartan Produkt AB
mailto: ao at t-kartor.se
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/6f5f2693/attachment.html
