[gdal-dev] Re: FileGDB OGR driver test
Ragi Burhum
ragi at burhum.com
Wed Apr 13 14:13:55 EDT 2011
Perfect. Thank you Michael.
- Ragi
> Date: Tue, 12 Apr 2011 15:45:25 -0400
> From: "Smith, Michael ERDC-CRREL-NH" <michael.smith at usace.army.mil>
> Subject: Re: [gdal-dev] Re: FileGDB OGR driver test
> To: Even Rouault <even.rouault at mines-paris.org>,
> <gdal-dev at lists.osgeo.org>
> Message-ID: <C9CA2415.2220D%michael.smith at usace.army.mil>
> Content-Type: text/plain; charset="ISO-8859-1"
> I have a test v10 filegdb with points, lines, polygons (all with Z and M
> but
> I think the measures aren't populated). There are also some non geometry
> tables and some relationship classes.
> Its available at
> http://12.189.158.78:8081/downloads/test_fgdb.gdb.zip
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> On 4/12/11 2:48 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> > Le mardi 12 avril 2011 20:40:58, Matt Wilkie a écrit :
> >>> ArcGIS 10 FileGDB's right ?
> >> If the api allows for using gdb's from different versions then the test
> >> suite should have different versions too. In any case I can make v10
> gdb's.
> > No, the FileGDB API only reads v10 gdb's.
> >>> Current GDAL trunk builds against FileGDB API beta3 under Linux 32bit.
> >>> Too bad ESRI doesn't provide any 64bit build of the FileGDB API (yet...
> >> We are working on a Linux 64-bit release of the File Geodatabase API. It
> >> will not release with the 1.0 release of the API, but as a part of a
> >> follow on release later this year.
> >> Lance Shipman
> >> Geodatabase Product Engineer, File Geodatabase
> >> esri
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/6997f9d6/attachment.html
