[gdal-dev] Re: dev-version of HDF4
Nikolaos Hatzopoulos nhatzop at gmail.com
Wed Apr 20 11:03:22 EDT 2011
when does the gcc ....
you must have: -L/Users/knutfd/Software/hdf-4.2.5/lib
in order to find the lib
so you need to do before the compile:
export LDFLAGS="$LDFLAGS -L/Users/knutfd/Software/hdf-4.2.5/lib"
and obviously you are going to need the include files also:
export CPPFLAGS="$CPPFLAGS -I/Users/knutfd/Software/hdf-4.2.5/include"
I am not quite sure if export is going to work or setenv
in setenv you don't need the equal I am not an expert in c shell
this kind of problem is because the tools are not install in a standard path
library
like /usr/lib and /usr/include so you have to define compilation flags
On Wed, Apr 20, 2011 at 6:11 AM, Knut-Frode Dagestad <
knutfrodesoppel at hotmail.com> wrote:
> I forgot to say, but I have also tried by specifying the location of HDF4,
> with similar error:
> checking for SDreaddata in -lmfhdfalt... no
> checking for SDreaddata in -lmfhdf... no
> checking for SDreaddata in -lhdf4... no
> configure: error: HDF4 support requested with arg
> "/Users/knutfd/Software/hdf-4.2.5/", but neither hdf4 nor mfhdf lib found
> HDF4 library is there, but somehow configure is not able to detect it. HDF4
> is compiled without SLIB, so that should not be the problem.
> I have also tried with older version of HDF4 (4.2r1), other installation
> points, and prebuilt binaries. And I compiled with options --disable-fortran
> --disable-netcdf --with-pic, as suggested on
> http://osgeo-org.1803224.n2.nabble.com/Error-in-GDAL-compiling-with-HDF4-td3351437.html
> It has been suggested to use a "dev" version of HDF4, but I don't know if
> that would solve this problem?
> Best regards from Knut-Frode
> On 19/04/2011 21:51, Nikolaos Hatzopoulos wrote:
>> hdf4 libraries not found that's what the log says :)
>> do a
>> locate libhdf4
>> to see where the library is
>> On Tue, Apr 19, 2011 at 10:24 AM, Knut-Frode Dagestad
>> <knutfrodesoppel at hotmail.com <mailto:knutfrodesoppel at hotmail.com>> wrote:
>>    I am trying to compile GDAL from source with support for HDF4 with:
>>    ./configure --with-hdf4
>>    but get complaints about missing libraries, see extract from
>> config.log:
>>    ld: library not found for -lmfhdfalt
>>    ld: library not found for -lhdf4
>>    configure:19940: checking for SDreaddata in -lmfhdf
>>    configure:19965: gcc -o conftest -g -O2   conftest.c -lmfhdf -ldf
>>    -lsz -ljpeg -lz -lz -lpthread -ldl >&5
>>    configure:20009: error: HDF4 support requested with arg "yes", but
>>    Similar errors are also reported by others, e.g. this one using
>>    mapserver:
>> http://osgeo-org.1803224.n2.nabble.com/cannot-find-lmfhdf-td5286909.html
>>    I have tried with various versions of HDF4, both binaries and
>>    compiled from source. The link above (and also
>>    http://trac.osgeo.org/gdal/wiki/BuildingOnUnix) suggests to try a
>>    "hdf-dev" version. But where can I find such "dev-versions", in my
>>    case for Mac OS X 10.6.7?
>>    Would it be possible to update GDAL to work with standard HDF4
>>    libraries?
>>    _______________________________________________
>>    gdal-dev mailing list
>>    gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>    http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110420/f188db92/attachment.html
