[gdal-dev] Re: dev-version of HDF4
Knut-Frode knutfrodesoppel at hotmail.com
Wed Apr 20 11:27:37 EDT 2011
The paths are taken care of by configure, and they are checked to be ok.
I also tried with standard installation folders (/usr/lib/ /usr/include/
etc) but no difference. I did not compile, since configure fails.
So I believe it must be some incompatibility with the GDAL configure
script and the standard HDF4-libraries I have used. The "lib not found"
message from GDAL configure seems to be misleading.
Best regards from Knut-Frode
Den 20.04.2011 17:03, skrev Nikolaos Hatzopoulos:
> when does the gcc ....
> you must have: -L/Users/knutfd/Software/hdf-4.2.5/lib
> in order to find the lib
> so you need to do before the compile:
> export LDFLAGS="$LDFLAGS -L/Users/knutfd/Software/hdf-4.2.5/lib"
> and obviously you are going to need the include files also:
> export CPPFLAGS="$CPPFLAGS -I/Users/knutfd/Software/hdf-4.2.5/include"
> I am not quite sure if export is going to work or setenv
> in setenv you don't need the equal I am not an expert in c shell
> this kind of problem is because the tools are not install in a standard
> path library
> like /usr/lib and /usr/include so you have to define compilation flags
> On Wed, Apr 20, 2011 at 6:11 AM, Knut-Frode Dagestad
> <knutfrodesoppel at hotmail.com <mailto:knutfrodesoppel at hotmail.com>> wrote:
>     I forgot to say, but I have also tried by specifying the location of
>     HDF4, with similar error:
>     checking for SDreaddata in -lmfhdfalt... no
>     checking for SDreaddata in -lmfhdf... no
>     checking for SDreaddata in -lhdf4... no
>     configure: error: HDF4 support requested with arg
>     "/Users/knutfd/Software/hdf-4.2.5/", but neither hdf4 nor mfhdf lib
>     found
>     HDF4 library is there, but somehow configure is not able to detect
>     it. HDF4 is compiled without SLIB, so that should not be the problem.
>     I have also tried with older version of HDF4 (4.2r1), other
>     installation points, and prebuilt binaries. And I compiled with
>     options --disable-fortran --disable-netcdf --with-pic, as suggested
>     on
>     http://osgeo-org.1803224.n2.nabble.com/Error-in-GDAL-compiling-with-HDF4-td3351437.html
>     It has been suggested to use a "dev" version of HDF4, but I don't
>     know if that would solve this problem?
>     On 19/04/2011 21:51, Nikolaos Hatzopoulos wrote:
>         hdf4 libraries not found that's what the log says :)
>         do a
>         locate libhdf4
>         to see where the library is
>         On Tue, Apr 19, 2011 at 10:24 AM, Knut-Frode Dagestad
>         <mailto:knutfrodesoppel at hotmail.com>>> wrote:
>             I am trying to compile GDAL from source with support for
>         HDF4 with:
>             ./configure --with-hdf4
>             but get complaints about missing libraries, see extract from
>         config.log:
>             ld: library not found for -lmfhdfalt
>             ld: library not found for -lhdf4
>             configure:19940: checking for SDreaddata in -lmfhdf
>             configure:19965: gcc -o conftest -g -O2   conftest.c -lmfhdf
>         -ldf
>             -lsz -ljpeg -lz -lz -lpthread -ldl >&5
>             configure:20009: error: HDF4 support requested with arg
>         "yes", but
>             neither hdf4 nor mfhdf lib found
>             Similar errors are also reported by others, e.g. this one using
>             mapserver:
>         http://osgeo-org.1803224.n2.nabble.com/cannot-find-lmfhdf-td5286909.html
>             I have tried with various versions of HDF4, both binaries and
>             compiled from source. The link above (and also
>         http://trac.osgeo.org/gdal/wiki/BuildingOnUnix) suggests to try a
>         "hdf-dev" version. But where can I find such "dev-versions", in my
>             case for Mac OS X 10.6.7?
>             Would it be possible to update GDAL to work with standard HDF4
>             libraries?
>             _______________________________________________
>             gdal-dev mailing list
>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         <mailto:gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
