[gdal-dev] Split apart MULTI* problem
William Kyngesburye
woklist at kyngchaos.com
Mon Apr 25 20:20:13 EDT 2011
I can't get ogr2ogr to split MULTI* shapefiles to non-multi features. I'm sure I've done this in the past (it's been a while).
ie, the Natural Earth shapefiles, coastline file - has a mix of LINESTRING and MULTILINESTRING. I run:
ogr2ogr . 50m_coastline.shp -nln 50m_coastline-l -nlt LINESTRING
It leaves the MULTILINESTRINGs as is.
Same happens with mixed POLYGON and MULTIPOLYGON shapefiles, like the NE admin_0_countries.
I've done something similar more recently importing shapefiles into PostGIS, forcing MULTI types to avoid errors in mixed multi/non-multi shapefiles. That works.
GDAL 1.8.0, OSX 10.6.7
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
