[gdal-dev] Split apart MULTI* problem
Luca Sigfrido Percich sigfrido at tiscali.it
Tue Apr 26 04:50:10 EDT 2011
Hi William,
converting a single linestring or polygon into a multi- geometry simply
wraps the single geom into a collection. Like in the U.K., when you see
a single person waiting at a bus stop, it's actually a queue made of a
single person :)
Splitting a multi geometry would result in multiple records - one per
element, probably with the same original attribute values, but with
different fids, which could be a problem if the original shape already
had valid primary key values. I'm not sure ogr2ogr can do that, but
probably there's an appropriate tool around, or you can explode the
multi geometries in PostGIS.
Best regards
Sig
Da: William Kyngesburye [woklist at kyngchaos.com], 26/04/2011 2.20
> I can't get ogr2ogr to split MULTI* shapefiles to non-multi features.  I'm sure I've done this in the past (it's been a while).
_____________
PRIVACY
Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
PRIVACY
This email was Anti Virus checked by Astaro Security Gateway. http://www.amat-mi.it
