[gdal-dev] FGDB Opening Sample File
Even Rouault even.rouault at mines-paris.org
Thu Apr 28 13:19:48 EDT 2011
Le jeudi 28 avril 2011 02:11:30, Paul Ramsey a écrit :
> I assume the failures are relationships we don't handle yet (or ever
> and will need to be silenced).
Not sure what those relations things are.
> There is a test file in the FGDB API itself, and it fails to open
> entirely, which seems odd,
> [pramsey at localhost data]$ ogrinfo ./TestData.gdb
> ERROR 1: GDB Error: Failed to open Geodatabase long:-2147467259
> FAILURE:
> Unable to open datasource `./TestData.gdb' with the following drivers.
> Do other folks have trouble opening the ESRI sample file? The error
> code doesn't make much sense, it is supposed to mean "If the path is
> seriously in error, say pointing to the wrong drive, a -2147467259
> (E_FAIL) error is returned" and relates to the CreateGeodatabase
> method, not the OpenGeodatabase method.
Yes I did notice that issue too. I assume either the example is corrupted,
either it is a bug in the FileGDB API, either... Perhaps reporting to ESRI
might be usefull. Or perhaps Ragi has some clues.
Even
