[gdal-dev] FGDB Opening Sample File
Smith, Michael ERDC-CRREL-NH michael.smith at usace.army.mil
Thu Apr 28 13:26:24 EDT 2011
Relations are joins to non-spatial tables containing domain values etc. They
are relational tables.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 4/28/11 1:19 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le jeudi 28 avril 2011 02:11:30, Paul Ramsey a écrit :
>> I assume the failures are relationships we don't handle yet (or ever
>> and will need to be silenced).
> Not sure what those relations things are.
>> There is a test file in the FGDB API itself, and it fails to open
>> entirely, which seems odd,
>> [pramsey at localhost data]$ ogrinfo ./TestData.gdb
>> ERROR 1: GDB Error: Failed to open Geodatabase long:-2147467259
>> FAILURE:
>> Unable to open datasource `./TestData.gdb' with the following drivers.
>> Do other folks have trouble opening the ESRI sample file? The error
>> code doesn't make much sense, it is supposed to mean "If the path is
>> seriously in error, say pointing to the wrong drive, a -2147467259
>> (E_FAIL) error is returned" and relates to the CreateGeodatabase
>> method, not the OpenGeodatabase method.
> Yes I did notice that issue too. I assume either the example is corrupted,
> either it is a bug in the FileGDB API, either... Perhaps reporting to ESRI
> might be usefull. Or perhaps Ragi has some clues.
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
