[gdal-dev] save raster as point-vector file
Mateusz Kędzior
matandked at gmail.com
Tue Aug 9 16:04:42 EDT 2011
Hi again,
is it mandatory to create such file?
Regarding to information on GDAL/OGR page should I create simple text file
which contains only other OGRVRTLayer name property :
<OGRVRTDataSource>
<OGRVRTLayer name="test">
<SrcDataSource>test.csv</SrcDataSource>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Longitude" y="Latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Best regards,
Mateusz
W dniu 9 sierpnia 2011 20:13 użytkownik Chaitanya kumar CH <
chaitanya.ch at gmail.com> napisał:
> Create a text file with just the header. Use the cat command to join this
> file and the xyz file.
> $ cat HeaderFile.csv file1.csv > file1.cHi sv
> You can repeat this on all files in a shell script.
> Otherwise add the following line in the gdal2xyz.py script at line 144 [1].
> dst_fh.write( 'Longitude,Latitude,Name' )
> You will also have to create a separate vrt file for each csv file. The
> SrcDataSource element value changes for each file.
> [1]:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal2xyz.py?rev=21127#L145
> 2011/8/9 Mateusz Kędzior <matandked at gmail.com>
>> Chaitanya,
>> if I understand properly, I need to add one line to each of processed
>> files.
>> How I can do it quickly? Is there any option in gdal2xyz.py script?
>> If no - what would You recommend?
>> I think about sed utility, but it's general difficult in use.
>> When I am thinking about Python I see only one possibility - load each
>> file to variable and then assign to another first line plus variable and at
>> last - save it.
>> Best Regards,
>> Mateusz
>> W dniu 9 sierpnia 2011 13:38 użytkownik Chaitanya kumar CH <
>> Mateusz,
>>> gdal2xyz.py creates space delimited fields. Consider running it with the
>>> -csv option to delimit it with comma.
>>> Now you can almost use it as a csv format vector file. You just need to
>>> add a header row and define a small VRT file as described in OGR's CSV
>>> driver page[1].
>>> Run ogrinfo and ogr2ogr on the .vrt file to check the file.
>>> [1]: http://www.gdal.org/ogr/drv_csv.html
>>>> Hello,
>>>> I would like to show value of each raster cell as label. My idea (I
>>>> don't know any plugin or any functionality in GDAL/OGR which allow to do it
>>>> easier) is to export raster using gdal2xyz.py into coordinates-value format
>>>> and then save it as vector (GML or shapefile). For this second task, I try
>>>> to use
>>>> gdal_polygonize.py:
>>>> gdal_polygonize.py rainfXYZ.txt rainf.shp Creating output rainf.shp of
>>>> format GML. 0...10...20...30...40...50...60...70...80...90...100 - done.
>>>> unfortunately I am unable to load created file (even if I change the
>>>> extension to .gml)
>>>> ogr2ogr tool don't even recognize this format.
>>>> Thank You in advance,
>>>> Mateusz
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> +91-9494447584
>>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110809/40616117/attachment-0001.html
