[gdal-dev] save raster as point-vector file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Aug 9 23:58:48 EDT 2011
Mateusz,
You have to change the OGRVRTLayer name property to point to the file name
without the extension. Also change the SrcDataSource element.
FYI, this process creates a vector file with points. gdal_polygonize
produces polygons.
2011/8/10 Mateusz Kędzior <matandked at gmail.com>
> Hi again,
> is it mandatory to create such file?
> Regarding to information on GDAL/OGR page should I create simple text file
> which contains only other OGRVRTLayer name property :
> <OGRVRTDataSource>
> <OGRVRTLayer name="test">
> <SrcDataSource>test.csv</SrcDataSource>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="Longitude" y="Latitude"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Best regards,
> Mateusz
> W dniu 9 sierpnia 2011 20:13 użytkownik Chaitanya kumar CH <
> chaitanya.ch at gmail.com> napisał:
>> Create a text file with just the header. Use the cat command to join this
>> file and the xyz file.
>> $ cat HeaderFile.csv file1.csv > file1.cHi sv
>> You can repeat this on all files in a shell script.
>> Otherwise add the following line in the gdal2xyz.py script at line 144
>> [1].
>> dst_fh.write( 'Longitude,Latitude,Name' )
>> You will also have to create a separate vrt file for each csv file. The
>> SrcDataSource element value changes for each file.
>> [1]:
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal2xyz.py?rev=21127#L145
>> 2011/8/9 Mateusz Kędzior <matandked at gmail.com>
>>> Chaitanya,
>>> if I understand properly, I need to add one line to each of processed
>>> files.
>>> How I can do it quickly? Is there any option in gdal2xyz.py script?
>>> If no - what would You recommend?
>>> I think about sed utility, but it's general difficult in use.
>>> When I am thinking about Python I see only one possibility - load each
>>> file to variable and then assign to another first line plus variable and at
>>> last - save it.
>>> Best Regards,
>>> Mateusz
>>> W dniu 9 sierpnia 2011 13:38 użytkownik Chaitanya kumar CH <
>>> Mateusz,
>>>> gdal2xyz.py creates space delimited fields. Consider running it with the
>>>> -csv option to delimit it with comma.
>>>> Now you can almost use it as a csv format vector file. You just need to
>>>> add a header row and define a small VRT file as described in OGR's CSV
>>>> driver page[1].
>>>> Run ogrinfo and ogr2ogr on the .vrt file to check the file.
>>>> [1]: http://www.gdal.org/ogr/drv_csv.html
>>>>> Hello,
>>>>> I would like to show value of each raster cell as label. My idea (I
>>>>> don't know any plugin or any functionality in GDAL/OGR which allow to do it
>>>>> easier) is to export raster using gdal2xyz.py into coordinates-value format
>>>>> and then save it as vector (GML or shapefile). For this second task, I try
>>>>> to use
>>>>> gdal_polygonize.py:
>>>>> gdal_polygonize.py rainfXYZ.txt rainf.shp Creating output rainf.shp of
>>>>> format GML. 0...10...20...30...40...50...60...70...80...90...100 - done.
>>>>> unfortunately I am unable to load created file (even if I change the
>>>>> extension to .gml)
>>>>> ogr2ogr tool don't even recognize this format.
>>>>> Thank You in advance,
>>>>> Mateusz
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110810/111be4fe/attachment-0001.html
