[gdal-dev] VPF support
Sommer, Martin
Martin.Sommer at cassidian.com
Wed Aug 31 08:53:52 EDT 2011
Yehiyam,
current OGDI sources (betas) need a bit of tweaking, if you want it to build yourself.
Version 3.1.5 is far way better to build.
Best regards
Martin
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Wednesday, August 31, 2011 8:52 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] VPF support
On 11-08-30 11:24 PM, Livneh Yehiyam wrote:
> Hi
> I understand that for GDAL to support reading VPF files, I need to have the
> OGDI driver.
> Are there prebuilt binaries for windows 64 bit which include OGDI?
> Are there prebuilt binaries of OGDI itself, which I can use to build GDAL with
> that driver?
> thanks
Yehiyam,
The OSGeo4W binaries for GDAL 1.8 include OGDI support.
http://osgeo4w.osgeo.org/
I can be a bit involved to build OGDI yourself.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
