[gdal-dev] OGR PG Driver 1.8 to 1.9 undocumented functionality
change (bug?) with ExecuteSQL/GetSpatialRef
Even Rouault
even.rouault at mines-paris.org
Fri Dec 16 12:17:52 EST 2011
Le vendredi 16 décembre 2011 14:18:16, Silas Parker a écrit :
> Hi,
> I've updated my GDAL 1.9 build to SVN rev 23580 which is currently the
> head revision.
> I then ran the new commands and the previous set with the debug flag on.
> The standard (not SQL) based command works fine, the SQL with a space
> at the beginning still fails, SQL with no space at the beginning works
> fine.
Yes, that was indeed due to leading spaces and an unwanted side-effect of a
recent change. Fixed in r23581. Thanks for reporting.
