[gdal-dev] DXF to Postgis using ogr2ogr
Ralf Suhr Ralf.Suhr at itc-halle.de
Mon Dec 19 03:58:31 EST 2011
Hi Bob,
the dxf driver writes to tables "entities" and "blocks". You have to
dereference the block layer yourself.
SELECT Translate( Scale( Rotate((Dump(b.wkb_geometry)).geom, e.blockangle /
180 * PI()), e.blockscale[1], e.blockscale[2]), ST_X(e.wkb_geometry),
ST_Y(e.wkb_geometry)) AS wkb_geometry,
  CASE WHEN b.ogr_style IS NOT NULL THEN b.ogr_style ELSE e.ogr_style END AS
ogr_style,
  e.layer,
  e.linetype,
  e.subclasses,
  b.text
FROM entities e
  INNER JOIN
  blocks b USING (blockname);
Sometimes you have blocks with world coordinates and no connection in
entities.
SELECT (Dump(b.wkb_geometry)).geom AS wkb_geometry,
  b.ogr_style,
  b.layer,
  b.linetype,
  b.subclasses,
  b.text
FROM blocks b
WHERE blockname NOT IN
    SELECT DISTINCT blockname
    FROM entities
    WHERE blockname IS NOT NULL
Some newer DXF Formats can have features in paper space. This is now not
supported by ogr2ogr.
Gr
Ralf
On Freitag 16 Dezember 2011 22:14:38 Bob Pawley wrote:
> I have imported a dxf file into Postgis using the following command line -
> set DXF_INLINE_BLOCKS=FALSE&set DXF_MERGE_BLOCK_GEOMETRIES=FALSE&set
> PGCLIENTENCODING=LATIN1&&ogr2ogr -f "PostgreSQL" PG:"host=localhost
> user=postgres dbname=dbname password=pass"  W_Works.dxf -nln Import_PID
> -overwrite –skipfailures
> All geometries are intact.
> However, the text is part of the Linestring layer and not in the text
> column of the Postgresql table.
> Is this to be expected?
> Is there some way of screening out the text as text and point geometry?
> Bob
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111219/623db32e/attachment.html
