[gdal-dev] DXF to Postgis using ogr2ogr
Bob Pawley
rjpawley at shaw.ca
Mon Dec 19 11:21:58 EST 2011
Thanks Ralf
So far, I haven’t been able to populate the block columns unless I use a DXF file which has been exploded before saving.
In all of my searching, I have not come across your suggestion of dereferencing the block. Can you point me to some documentation?
Bob
Sent: Monday, December 19, 2011 12:58 AM
To: gdal-dev at lists.osgeo.org
Cc: Bob Pawley
Subject: Re: [gdal-dev] DXF to Postgis using ogr2ogr
Hi Bob,
the dxf driver writes to tables "entities" and "blocks". You have to dereference the block layer yourself.
SELECT Translate( Scale( Rotate((Dump(b.wkb_geometry)).geom, e.blockangle / 180 * PI()), e.blockscale[1], e.blockscale[2]), ST_X(e.wkb_geometry), ST_Y(e.wkb_geometry)) AS wkb_geometry,
CASE WHEN b.ogr_style IS NOT NULL THEN b.ogr_style ELSE e.ogr_style END AS ogr_style,
e.layer,
e.linetype,
e.subclasses,
b.text
FROM entities e
INNER JOIN
blocks b USING (blockname);
Sometimes you have blocks with world coordinates and no connection in entities.
SELECT (Dump(b.wkb_geometry)).geom AS wkb_geometry,
b.ogr_style,
b.layer,
b.linetype,
b.subclasses,
b.text
FROM blocks b
WHERE blockname NOT IN
SELECT DISTINCT blockname
FROM entities
WHERE blockname IS NOT NULL
Some newer DXF Formats can have features in paper space. This is now not supported by ogr2ogr.
Gr
Ralf
On Freitag 16 Dezember 2011 22:14:38 Bob Pawley wrote:
> I have imported a dxf file into Postgis using the following command line -
> set DXF_INLINE_BLOCKS=FALSE&set DXF_MERGE_BLOCK_GEOMETRIES=FALSE&set
> PGCLIENTENCODING=LATIN1&&ogr2ogr -f "PostgreSQL" PG:"host=localhost
> user=postgres dbname=dbname password=pass" W_Works.dxf -nln Import_PID
> -overwrite –skipfailures
> All geometries are intact.
> However, the text is part of the Linestring layer and not in the text
> column of the Postgresql table.
> Is this to be expected?
> Is there some way of screening out the text as text and point geometry?
> Bob
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111219/1a5f4458/attachment.html
