[gdal-dev] GDAL/OGR 1.9.0 Beta1 Released
Even Rouault
even.rouault at mines-paris.org
Wed Dec 21 12:24:55 EST 2011
Kyle,
Thanks for your report.
Nothing to worry particularly about :
- the gft failure is due to an authentication cookie to the test account that I
must renew regularly (~ 2 weeks). Not an ideal solution. I think I should make
that test to only report 'skip' if it fails. Or find a way to automate the
renewal.
- I somehow remember to have seen the 2 couchdb failures on builds where GDAL
was build without GEOS support ? Is it your case ?
Best regards,
Even
