[gdal-dev] GDAL/OGR 1.9.0 Beta1 Released
Kyle Shannon
ksshannon at gmail.com
Wed Dec 21 12:53:04 EST 2011
> - the gft failure is due to an authentication cookie to the test account
> that I
must renew regularly (~ 2 weeks). Not an ideal solution. I think I should
> make
that test to only report 'skip' if it fails. Or find a way to automate the
renewal.
Sounds good.
> - I somehow remember to have seen the 2 couchdb failures on builds where
> GDAL
was build without GEOS support ? Is it your case ?
Correct, rebuilding with GEOS support, I will rerun my tests.
Thanks Even.
kss
* Kyle Shannon
* ksshannon at gmail.com
On Wed, Dec 21, 2011 at 10:24, Even Rouault <even.rouault at mines-paris.org>wrote:
> Kyle,
> Thanks for your report.
> Nothing to worry particularly about :
> that I
> make
> renewal.
> GDAL
> Best regards,
> Even
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111221/82619bb5/attachment.html
