Hi, I'm using gdalbuildvrt to produce a virtual raster layer which can then used in Mapnik and its ogcserver(WMS), everything works except that the result image is black & white and with a very poor resolution. The 2 source tif files used in this test were both colored with a good resolution. Any ideas?
