[gdal-dev] nmake.local on windows builds
Fri Feb 11 18:59:36 EST 2011
On 11-02-11 06:56 PM, Tamas Szekeres wrote:
> Frank,
> While I'm not sure about what changes you intend to do here, I would
> emphatically disagree removing the current approach with the ability of setting
> the full path to the external configuration file from the nmake command line.
> My build system is higly depend on this setting and if we don't have any
> compelling reason I would like to avoid relocating this custom file (which is
> anyway generated dynamically) into the gdal source tree.
Tamas,
I did not remove the support for EXT_NMAKE_OPT - the first stuff in
nmake.opt now looks like:
# For convenience, user may put custom settings in a local settings file
# named nmake.local, or a name defined by the EXT_NMAKE_OPT option.
!IF EXIST("$(GDAL_ROOT)\nmake.local")
!INCLUDE $(GDAL_ROOT)\nmake.local
!ENDIF
# nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
!IFDEF EXT_NMAKE_OPT
!INCLUDE $(EXT_NMAKE_OPT)
!ENDIF
I believe this will serve both needs smoothly, albeit with a little
extra complication in the nmake.opt.
Best regards,
