[gdal-dev] nmake.local on windows builds
Tamas Szekeres
szekerest at gmail.com
Sat Feb 12 07:28:35 EST 2011
Looks good.
Tamas
2011/2/12 Frank Warmerdam <warmerdam at pobox.com>
> On 11-02-11 06:56 PM, Tamas Szekeres wrote:
>> Frank,
>> While I'm not sure about what changes you intend to do here, I would
>> emphatically disagree removing the current approach with the ability of
>> setting
>> the full path to the external configuration file from the nmake command
>> line.
>> My build system is higly depend on this setting and if we don't have any
>> compelling reason I would like to avoid relocating this custom file (which
>> is
>> anyway generated dynamically) into the gdal source tree.
> Tamas,
> I did not remove the support for EXT_NMAKE_OPT - the first stuff in
> nmake.opt now looks like:
> # For convenience, user may put custom settings in a local settings file
> # named nmake.local, or a name defined by the EXT_NMAKE_OPT option.
> !IF EXIST("$(GDAL_ROOT)\nmake.local")
> !INCLUDE $(GDAL_ROOT)\nmake.local
> !ENDIF
> # nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
> !IFDEF EXT_NMAKE_OPT
> !INCLUDE $(EXT_NMAKE_OPT)
> !ENDIF
> I believe this will serve both needs smoothly, albeit with a little
> extra complication in the nmake.opt.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110212/fcde38e6/attachment.html
