[gdal-dev] nmake.local on windows builds
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 14 08:54:27 EST 2011
I personally have always just modified the nmake.opt. I am not sure
what is recommended now. Can someone verify that the new recommended
way is to create a 'nmake.local' file and then execute 'nmake /f
makefile.vc' ?
-jeff
On 11-02-11 6:27 PM, Frank Warmerdam wrote:
> Folks,
> Some time ago Tamas added a mechanism to nmake.opt (the central include
> file for windows MSVC nmake based makefiles) so that you could provide
> an extra definition file on the commandline.
> eg.
> nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
> While this is useful, expecially in cases where it is desirable to
> have several build configurations out of one tree, I never used it. I
> always just adding "!INCLUDE nmake.osgeo4w" or "!INCLUDE nmake.frank"
> at the beginning of nmake.opt and put my definitions in that new file.
> With Kirk's recent introduction of a complicated nmake.opt file for the
> MrSID driver, I've learned that you can check for the existance of a
> file in an nmake !IF EXISTS directive, and I have incorporated use of this
> in nmake.opt to pull in "nmake.local" if it exists.
> So going forward, I'm hoping the default way of tailoring windows builds
> will be to create an nmake.local file overriding definitions from
> nmake.opt.
> Best regards,
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
