[gdal-dev] nmake.local on windows builds
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 15 13:47:07 EST 2011
On 11-02-14 08:54 AM, Jeff McKenna wrote:
> I personally have always just modified the nmake.opt. I am not sure what is
> recommended now. Can someone verify that the new recommended way is to create a
> 'nmake.local' file and then execute 'nmake /f makefile.vc' ?
Jeff,
Well, either way will work. But *my* recommendation is creating an
nmake.local with GDAL trunk and beyond. This is better than editing
nmake.opt directly particularly in the case where you later want to
do svn update's and rebuilds. If you hand edit the nmake.opt there is
a significant risk of needless merge conflicts.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
