[gdal-dev] GCP list projection
Vadim Shlyakhov vadp.devl at gmail.com
Thu Feb 17 10:08:26 EST 2011
Hello,
I wonder if it makes any sense if GCP list at a dataset is different from
the dataset's SRS.
I've played a little with these in Python, but neither gdal.Transformer, nor
warping via VRT doesn't produce the results expected. I mean, presumably if
GCP's SRS is different from the dataset's SRS, then they are to be
transformed internally into the dataset SRS, but this doesn't seem to happen
Regards
V
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110217/9e1ef8f5/attachment.html
