[gdal-dev] Re: gdal android
Even Rouault even.rouault at mines-paris.org
Thu Feb 17 13:33:15 EST 2011
Le jeudi 17 février 2011 15:58:17, Frank Warmerdam a écrit :
> On 11-02-17 06:00 AM, Mohammed Rashad wrote:
> > here is my new error log
> > cpl_strtod.cpp: In function 'void CPLReplacePointByLocalePoint(char*,
> > char)': cpl_strtod.cpp:200: error: 'struct lconv' has no member named
> > 'decimal_point' cpl_strtod.cpp:201: error: 'struct lconv' has no member
> > named 'decimal_point' cpl_strtod.cpp:204: error: 'struct lconv' has no
> > member named 'decimal_point' make[1]: *** [cpl_strtod.lo] Error 1
> > make[1]: Leaving directory `/home/rashadkm/gdal-1.8.0/port'
> > make: *** [port-target] Error 2
> > Which gdal version to use for Android
> Rashad,
> My copy of cpl_strtod.cpp (trunk) has an ifdef in that function for the
> __ANDROID__ case.  Do you?  If yes, I wonder why it isn't getting
> activated.
> Perhaps you should review the fairly new android notes at:
>    http://trac.osgeo.org/gdal/wiki/BuildingForAndroid
> Best regards,
I see that the path is /home/rashadkm/gdal-1.8.0/port so I deduce this is a
GDAL 1.8.0 build. But the adjustment for Android has been introduced in trunk
(1.9.0dev) very recently. See http://trac.osgeo.org/gdal/ticket/3952
