[gdal-dev] Re: gdal android
Mohammed Rashad
mohammedrashadkm at gmail.com
Thu Feb 17 13:59:56 EST 2011
I installed gdal-1.5.0 on android with some patches.
there is a problem in tiff format, gml,geojson,kml all other formats worked
without any patch
will send you those patches if needed
On Fri, Feb 18, 2011 at 12:03 AM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Le jeudi 17 février 2011 15:58:17, Frank Warmerdam a écrit :
> > On 11-02-17 06:00 AM, Mohammed Rashad wrote:
> > > here is my new error log
> > > cpl_strtod.cpp: In function 'void CPLReplacePointByLocalePoint(char*,
> > > char)': cpl_strtod.cpp:200: error: 'struct lconv' has no member named
> > > 'decimal_point' cpl_strtod.cpp:201: error: 'struct lconv' has no member
> > > named 'decimal_point' cpl_strtod.cpp:204: error: 'struct lconv' has no
> > > member named 'decimal_point' make[1]: *** [cpl_strtod.lo] Error 1
> > > make[1]: Leaving directory `/home/rashadkm/gdal-1.8.0/port'
> > > make: *** [port-target] Error 2
> > > Which gdal version to use for Android
> > Rashad,
> > My copy of cpl_strtod.cpp (trunk) has an ifdef in that function for the
> > __ANDROID__ case. Do you? If yes, I wonder why it isn't getting
> > activated.
> > Perhaps you should review the fairly new android notes at:
> > http://trac.osgeo.org/gdal/wiki/BuildingForAndroid
> > Best regards,
> I see that the path is /home/rashadkm/gdal-1.8.0/port so I deduce this is a
> GDAL 1.8.0 build. But the adjustment for Android has been introduced in
> trunk
> (1.9.0dev) very recently. See http://trac.osgeo.org/gdal/ticket/3952
Thanks && Regards
Rashad
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110218/0baa6d94/attachment.html
