[gdal-dev] Gdal2tiles in Gdal18 and creating KMZ files
Vincent Schut
schut at sarvision.nl
Fri Feb 18 02:34:29 EST 2011
Roland,
not really an answer to your question, but note that - with a recent
gdal - you can also create kmz by using the kmlsuperoverlay output
format, e.g.:
gdal_translate -of kmlsuperoverlay <infile> out.kmz
your infile need be a rgb or rgba format (if you want to maintain
transparency, add '-co format=png' to the gdal_translate command,
otherwise jpeg's will be created for the tiles).
Regards,
Vincent.
On 02/17/2011 06:28 PM, Roland Duhaime wrote:
> Thanks Brian,
> I have reviewed OSGeo4W\bin\gdal2tiles.py and specifically line 1597
> containing the href tag to the png file:
> <Icon>
> <href>%(ty)d.%(tileformat)s</href>
> </Icon>
> I was curious if someone had any idea on how to modify this href tag to
> include the relative path as Brian suggests below. I see that the
> appropriate path is already included in the name tag if the .kml is
> changed to .png. Any ideas on the best approach would be appreciated.
> Also, is this relative path something that should be added to the
> general release to support kmz compression?
> Thanks,
> Roland
> On Wed, Feb 16, 2011 at 5:35 PM, brian <rush at winkey.org
> <mailto:rush at winkey.org>> wrote:
> Roland
> the problem is in /12/1211/2558.kml line 26
> <href>2558.png</href>
> this should be a relative path from the root of the zipfile not from
> 2558.kml
> Brian
> On Wed, 2011-02-16 at 15:14 -0500, Roland Duhaime wrote:
> > I am following the instructions for creating one KMZ file that are
> > posted here:
> > http://trac.osgeo.org/gdal/wiki/UserDocs/Gdal2Tiles
> > I am using gdal2tiles under the "gdal" package 1.8. I have having
> > success creating superoverlays and the related folder structure.
> I am
> > able to read the created doc.kml in Google Earth. However, when I
> > attempt to zip up the folder structure using 7zip and rename the file
> > to test.kmz, the file doesn't read properly in Google Earth (GE). GE
> > zooms into the correct location but all I see is a red "x".
> > Compressing the superoverlay structure seems to break the link
> between
> > the doc.kml file and the png files. As an example, I have created a
> > tiny (21 KB) example and placed it here:
> > http://www.edc.uri.edu/Personal/roland/test.kmz
> > I am curious if someone had some insight.
> > All the Best,
> > Roland
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
