[gdal-dev] How to use GDAL C++ dynamically?
Frank Warmerdam
warmerdam at pobox.com
Wed Feb 23 14:05:01 EST 2011
On 11-02-22 08:41 PM, Mikhail Tchernychev wrote:
> I just tried: If I declare make functions of OGRSFDriverRegistrar as virtual,
> everything is working as expected.
> Most of the functions of other classes are virtual, why those are not?
Mikhail,
They are not virtual because it is not part of our pattern to
derive subclasses from OGRSFDriverRegistrar. I think you will find there
are other classes that don't use virtual methods including OGRFeature. If
your technique depends on this, I think you will get frustrated.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
