[gdal-dev] Windows builds and wildcard usage for gdaltindex & gdalbuildvrt
Tamas Szekeres szekerest at gmail.com
Thu Feb 24 16:40:08 EST 2011
Hi Armin,
I've just added wildcard support to the builds at
http://vbkto.dyndns.org/sdk/ according to Frank's suggestion. The
corresponding binaries should be available with the next daily builds.
Best regards,
Tamas
2011/2/24 Armin Burger <armin.burger at gmx.net>
> Hi all
> I wanted to use a more recent Windows build than the latest FW Tools which
> are a bit old now. I used the binaries from
> http://vbkto.dyndns.org/sdk/PackageList.aspx?file=release-1310-gdal-1-8-0-mapserver-5-6-6.zip
> All works fine, just the usage of wildcards in tools like gdaltindex or
> gdalbuildvrt does not work any more. If I run eg
> gdaltindex tileindex.shp *.tif
> I just get the error that the file "*.tif" could not be found. Same happens
> for gdalbuildvrt.exe.  So the wildcard resolution seems not to work any more
> (it still did work in the last FWTools 2.4.7). For gdaltindex I can use a
> "for" loop command because it adds every tif to the same shape, but I don't
> think this workaround works for the gdalbuildvrt.
> On Linux builds the wildcards usage still works fine with GDAL 1.8. Any
> ideas if this will be fixed for Windows?
> Armin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110224/7fa4d086/attachment.html
