[gdal-dev] Re: Converting contour lines (Shape files) into DEM
Martinjensen martin.martinjensen at gmail.com
Sun Feb 27 16:00:49 EST 2011
I am trying the same thing but gdal_rasterize will not let me without an
existing raster  outputfile. My GDAL version is:
>gdal_rasterize --utility_version
gdal_rasterize was compiled against GDAL 1.8.0 and is running against GDAL
1.8.0
I run it like this:
gdal_rasterize.exe -a Z -l LINESTRING LINESTRING.shp LINESTRING_dem.tif
ERROR 4: `LINESTRING_dem.tif' does not exist in the file system,
and is not recognised as a supported dataset name.
I thought the ability to create new output file by gdal_rasterize war
introduced en GDAL 1.8.
Am I doing anything wrong?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Converting-contour-lines-Shape-files-into-DEM-tp4810148p6071139.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
