[gdal-dev] Re: Lost in projections
K.-Michael Aye
kmichael.aye at gmail.com
Mon Feb 28 06:43:17 EST 2011
To make the sad long story short:
I was missing (=not knowing about) one method of the SpatialReference
class: CloneGeogCS()
So if you do:
srs = osr.SpatialReference(gdaldataset.GetProjection())
and that projection is in map coordinates, to get the same thing in
geographical coordinates one just has to do:
targetSRS = srs.CloneGeogCS()
and then to convert one into another :
transform = osr.CoordinateTransformation(srs,targetSRS)
and then for example:
lon, lat, height = transform.TransformPoint(x,y)
It is instructive to look at both srs and targetSRS.ExportToPrettyWkt()
to see the differences.
HTH others,
Michael
On 2011-02-27 16:15:56 +0100, K.-Michael Aye said:
> I just can't get my head around it... :(
> I have a Mars DEM rasterdata set that is projected in polar
> stereographic with this Wkt:
> PROJCS["POLAR_STEREOGRAPHIC MARS",
> GEOGCS["GCS_MARS",
> DATUM["D_MARS",
> SPHEROID["MARS",3396190,169.8944472236118]],
> PRIMEM["Reference_Meridian",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Polar_Stereographic"],
> PARAMETER["latitude_of_origin",-90],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0]]
> and a worldfile (output of ds.GetGeoTransform()
> (-707109.6954345703,
> 115.08946865797043,
> 0.0,
> 707109.6954345703,
> 0.0,
> -115.08946865797043)
> So, currently, to find the corrent sample/line coordinates to determine
> what raster window to read, I need to know the projected coordinate in
> meters and using this via gdal.ApplyGeoTransform() works fine, in both
> directions.
> But I would like to find my data by providing a pair of unprojected,
> i.e. geographical coordinates. So something like
> sample, line = gdal.ApplyGeoTransform(t, lat,lon)
> So I understand that I need a transformation between
> polar_stereographic and lat/long projection, but I am stumped at how I
> get a new wordfile?
> I guess I can just take the above Wkt and change projection to lat/long
> and remove the parameter section, but what do I do with the affine
> transformation parameters? Where do I have to put them into the proj4
> system to achieve what I need? Somehow no examples I can find explain
> this part (or I can't see the forest because of all the trees.)
> Any help would be appreciated deeply!!
> Best regards,
> Michael
