[gdal-dev] Problem with gdal 1.8 -- segmentation fault on large
image with gdaladdo
Stephen Mather
mather.stephen at gmail.com
Sat Jan 1 11:34:57 EST 2011
Seems large enough for me.
Stephen Mather
On Jan 1, 2011, at 5:47 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
>> What's the new ceiling on image size for overview calculation?
> The same as before hopefully. I'm not sure what the limit is. From a quick look
> at the code, I'd say perhaps if the raster_width * 64 > 2 billion. This could be
> probably overcomeby modifying the algorithm if it became a limit in real use
> cases, but I'm not aware of someone having reported it up to here...
>> Steve
>> On Fri, Dec 31, 2010 at 11:38 AM, Even Rouault <even.rouault at mines-paris.org
>>> wrote:
>>> Stephen,
>>> this should be fixed now in SVN.
>>> This was indeed something wrong in a recent optimization in overview
>>> computation. This could cause integer overflow, that was triggered when
>>> dealing
>>> with a dataset where width * height > 2 billion.
>>> Thanks for reporting !
