Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
    Ari Jolma
    ari.jolma at gmail.com
    Thu Jan  6 15:13:32 EST 2011
Tamas,
In Perl the programmer can postpone loading the external DLL required by
a module. Thus a similar approach is viable in Perl. But that's not how
it's usually done. If you have a DLL in a system that is meant for
shared use then it should be in the system PATH. Thus I believe the
policy should be to set the PATH if GDAL is installed into a system (as
such - not as a part of something else). Only if a package installs a
private GDAL, it should be kept out of PATH and the package executables
need to take care of setting the PATH or other env vars as appropriate
(in Geoinformatica I do this - the Geoinformatica installer is basically
a file copy and no env vars are changed).
Ari
6.1.2011 16:50, Tamas Szekeres kirjoitti:
> Ari
> The only wokaround which is satisfactory to me is to set the required
> enviroment at run time before the gdal bindings are used. In csharp we
> can do something like:
>                     string path =
> Environment.GetEnvironmentVariable("PATH");
>                     if (!path.Contains(gdal_bin_path))
>                         Environment.SetEnvironmentVariable("PATH",
> gdal_bin_path + ";" + path);
>                     Gdal.SetConfigOption("GDAL_DRIVER_PATH",
> gdal_driver_path);
> But it requires that loading the gdal dll is happening when the
> interface is used actually (in Gdal.SetConfigOption with the code
> above). This is the case with the .NET runtime,  but I'm not sure how
> do we stand with the other bindings in this regard.
> Futher problem with this solution is that this startup code should be
> placed in the user's script and not sure how this could be implemented
> in the gdal bindings itself.
> Best regards,
> Tamas
> 2011/1/6 Ari Jolma <ari.jolma at gmail.com <mailto:ari.jolma at gmail.com>>
>     On 01/06/2011 03:25 PM, Tamas Szekeres wrote:
>         Assuming we install the gdal-perl modules in a standard
>         location (not sure where it is), do we have a common mechanism
>         in the perl runtime to find the dependent dlls without having
>         to violate system wide settings (like the PATH environment
>         variable)?
>     :) I'm not completely satisfied (I'm also not sure I really
>     understand the whole f* issue) with how Perl searches for dll's -
>     especially dll import libs - in Windows.
>     But that's configure/compile time issue. In compile time a Perl
>     GDAL dll (for the bindings) is created and put into some location,
>     which is known to Perl and Perl knows how to find it in runtime.
>     Assuming I've built the binaries, then in runtime (when the GDAL
>     module is called for) I think somebody (because the Perl GDAL
>     module dll has a link to GDAL dll that was put there in compile
>     time) asks for the GDAL dll's and they simply need to be
>     available. Thus, if there is GDAL in the system (for example in
>     c:\Program Files\Share\GDAL\bin) then that path needs to be in the
>     PATH - I don't think there is a way around that. The PATH may be a
>     temporary PATH set by somebody for Perl programs, but I think the
>     policy should be that when you run GDAL.msi, the system default
>     PATH is modified to have the path to the GDAL binaries.
>     Best regards,
>     Ari
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110106/010eada6/attachment.html
