Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Christopher Barker Chris.Barker at noaa.gov
Thu Jan 6 15:20:02 EST 2011
On 1/6/11 12:13 PM, Ari Jolma wrote:
>  If you have a DLL in a system that is meant for
> shared use then it should be in the system PATH. Thus I believe the
> policy should be to set the PATH if GDAL is installed into a system
I notice on my system, the dll is "gdal17.dll"
That is, the version is part of the file name, so there shouldn't be a
problem with different versions installed in the PATH.
WE could even use a longer filename, like *nix systems, we're not
restricted to 8.3 anymore, are we?
gdal-1.7.1-a.dll
for instance.
Though maybe setting up the build to do that is more trouble that it's
worth.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
