[gdal-dev] gdal_polygonize.py binding error
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jan 6 23:11:08 EST 2011
Xiaodong,
Check again after setting the environment variable PYTHONPATH to the path to
the new python bindings.
On Fri, Jan 7, 2011 at 12:55 AM, Xiaodong Zhang <xiaodong.zhang2 at und.edu>wrote:
> Hi,
> I just updated the older version of gdal (1.4.2) with the latest version
> of gdal (1.7.3) on x64 RedHat. Got an error when using gdal_polygonize.py
> for a test image
> gdal_polyzonize.py t2.tif -f "ESRI Shapefile" pt2
> gdal.Polyzonize() not available. You are likely using "old gen" bindings or
> an older version of the next gen bindings.
> I found the previous threads on this issue, but could not find an answer.
> Any idea? Thanks
> Xiaodong
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110107/7f2334c2/attachment.html
